BW55: welke artikelnrs obv serienummer?
#41
Kijk, mooie reacties. Daar kunnen we verder mee Smile
Via de link van oudevolvo:
[TABLE="width: 604"]
<tbody>[TR]
[TD="class: xl27, width: 72, bgcolor: transparent"]Gearbox[/TD]
[TD="class: xl27, width: 64, bgcolor: transparent"]Axelratio[/TD]
[TD="class: xl28, width: 64, bgcolor: transparent"]Small gear[/TD]
[TD="class: xl29, width: 64, bgcolor: transparent"]Teeth[/TD]
[TD="class: xl30, width: 64, bgcolor: transparent"]Color[/TD]
[TD="class: xl28, width: 71, bgcolor: transparent"]Large gear[/TD]
[TD="class: xl29, width: 64, bgcolor: transparent"][/TD]
[TD="class: xl24, width: 64, bgcolor: transparent"]Ratio[/TD]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TD="class: xl33, bgcolor: transparent"][TABLE="width: 604"]
<tbody>[TR]
[TD="class: xl33, bgcolor: transparent"][/TD]
[TD="class: xl33, bgcolor: transparent"]BW 35[/TD]
[TD="class: xl33, bgcolor: transparent"]3,91:1[/TD]
[TD="class: xl33, bgcolor: transparent"]381600[/TD]
[TD="class: xl33, bgcolor: transparent"]20[/TD]
[TD="class: xl33, bgcolor: transparent"]Black[/TD]
[TD="class: xl33, bgcolor: transparent"]381602[/TD]
[TD="class: xl33, bgcolor: transparent"]6[/TD]
[TD="class: xl26, bgcolor: transparent"]3,33:1[/TD]
[/TR]
[TR]
[TD="class: xl33, bgcolor: transparent"]4,10:1[/TD]
[TD="class: xl33, bgcolor: transparent"]381603[/TD]
[TD="class: xl33, bgcolor: transparent"]21[/TD]
[TD="class: xl33, bgcolor: transparent"]Dark red[/TD]
[TD="class: xl26, bgcolor: transparent"]3,50:1[/TD]
[/TR]
[TR]
[TD="class: xl26, bgcolor: transparent"][/TD]
[/TR]
[TR]
[TD="class: xl33, bgcolor: transparent"]BW 55[/TD]
[TD="class: xl33, bgcolor: transparent"]3,31:1[/TD]
[TD="class: xl33, bgcolor: transparent"]380978[/TD]
[TD="class: xl33, bgcolor: transparent"]17[/TD]
[TD="class: xl33, bgcolor: transparent"]Cream[/TD]
[TD="class: xl33, bgcolor: transparent"]380977[/TD]
[TD="class: xl26, bgcolor: transparent"]2,83:1[/TD]
[/TR]
[TR]
[TD="class: xl33, bgcolor: transparent"]3,54:1[/TD]
[TD="class: xl33, bgcolor: transparent"]380979[/TD]
[TD="class: xl33, bgcolor: transparent"]18[/TD]
[TD="class: xl33, bgcolor: transparent"]Red[/TD]
[TD="class: xl26, bgcolor: transparent"]3,00:1[/TD]
[/TR]
[TR]
[TD="class: xl33, bgcolor: transparent"]3,73:1[/TD]
[TD="class: xl33, bgcolor: transparent"]380980[/TD]
[TD="class: xl33, bgcolor: transparent"]19[/TD]
[TD="class: xl33, bgcolor: transparent"]Kaki[/TD]
[TD="class: xl26, bgcolor: transparent"]3,16:1[/TD]
[/TR]
[TR]
[TD="class: xl33, bgcolor: transparent"]1220484[/TD]
[TD="class: xl33, bgcolor: transparent"]Yellow[/TD]
[/TR]
</tbody>[/TABLE]
Ik had een donkerrood wieltje in de BW35 en een rode in de BW55.
Klopt deze gedachtegang? -->
ik heb nu een tandwieltje nodig met een ratio zo dicht mogelijk bij de 4,10, of zo dicht mogelijk bij de 21 tandjes...?
Dat is de gele 3,91 met 20 tandjes. Dus de afwijking blijft.
Tijdens het rijden maakt de wagen met de BW55 toch nog steeds bizar veel toeren. Ik heb gevoel dat hij bij 100 meer toeren maakt dan destijds met de BW35. Kan dat?
Is het dan nog een idee om een andere achteras met differentieel te plaatsen zodat er een langere overbrenging is? Of heeft de B21A/BW35-achteras al de langste overbrenging? (of heeft een diff gewoon 1op1 vertanding/overbrenging?)[/TD]
[/TR]
</tbody>[/TABLE]
Voor een AW70/71 is mijn tunnel te klein en dan moet ik daar in slijpen/lassen. Dat heeft nog steeds niet mijn voorkeur.
  Is dit een BW55? hugo 3 1.472 7 August 2025, 21:29
  Welke motor voor AW 72 bak. Madman 7 3.564 19 January 2025, 21:07
  Welke olie in sperdifferentieel 940 i.c. bj. 96 JanO 2 2.116 4 December 2022, 22:32
  KM kabel voor AW71+BW55 staartstuk Yezzz 6 5.435 27 January 2021, 09:32
Laatste bericht: Yezzz
  BW55 vraagjes jos245 6 6.177 30 August 2020, 13:51
  Welke automaat? Archermusic 10 9.969 13 August 2019, 15:29
Laatste bericht: aRjen.T
  Staartstuk BW55 swap naar AW71 gerbenvdlindeu 9 7.872 29 March 2019, 09:48
  welke achteras volvo 240 voor een P1800es? gydomatra 12 18.202 28 September 2018, 15:28
  welke M47? jos245 1 3.381 24 January 2018, 17:00
Laatste bericht: asterix
  Welke automaat Amazon 221 6 7.574 3 January 2018, 10:01
