Alle automaten... welke past op B21
Ik kwam onderstaand lijstje tegen. Welke bakken zijn er allemaal aan een 240 te knutselen ?
(245,1976,B21A, BW55.)
Home Tech - Versnellingsbakken Versnellingsbakken Volvo
Merk Model Bouwjaar Motor Bak Aandrijving Automaat
Volvo 240 1992-93 L4 2.3L 4 Spd RWD A42DL(03-70L)
Volvo 740 1990-92 L4 2.3L 4 Spd RWD A44DL(03-72L)
Volvo 740 1990-92 L4 2.3L(W/Turbo) 4 Spd RWD A43DL(03-71L)
Volvo 740 1990-92 L4 2.3L 4 Spd RWD A42DL(03-70L)
Volvo 850 1993-97 L5 2.3L 2.4L 4 Spd FWD 50-40(AW50-40)
Volvo 940 1992-95 L4 2.3L(W/Turbo) 4 Spd RWD A43DL(03-71L)
Volvo 960 1992-97 L6 2.9L 4 Spd RWD A341E(30-40LE)
Volvo C70 1998-00 L5 2.3L 2.4L 4 Spd FWD AW50-42LE
Volvo C70 2001-04 L5 2.3L 2.4L 5 Spd FWD AW55-50SN
Volvo C70 2006-07 L5 2.5L 5 Spd FWD AW55-50SN
Volvo CrossCountry 2002 L5 2.4L 5 Spd AWD AW55-50
Volvo S40 2000 L4 1.9L 4 Spd FWD AW50-42LE
Volvo S40 2001-04 L4 1.9L 5 Spd FWD AW55-50SN
Volvo S40 2005-07 L5 2.4L 2.5L 5 Spd FWD AW55-51SN
Volvo S40 2005-07 L5 2.5L 5 Spd AWD AW55-50
Volvo S60 2001-06 L5 2.3L 2.4L 5 Spd FWD AW55-50SN
Volvo S60 2003-07 L5 2.4L 2.5L 5 Spd FWD AW55-50SN
Volvo S60 2003-07 L5 2.5L 5 Spd AWD AW55-50
Volvo S60R 2006-07 L5 2.5L 6 Spd AWD TBD
Volvo S70 1998-00 L5 2.3L 2.4L 4 Spd FWD AW50-42LE
Volvo S70 2000 L5 2.4L 5 Spd FWD AW55-50SN
Volvo S70 2000 L5 2.4L 5 Spd AWD AW55-50
Volvo S80 1999-04 L5 2.4L:L 62.8L 2.9 L4 SpdFWD AW50-42LE
Volvo S80 1999-04 L5 2.5L 4 Spd FWD 4T65E
Volvo S80 2004-06 L5 2.5L 5 Spd FWD AW55-50SN
Volvo S80 2004-06 L5 2.5L 5 Spd AWD AW55-50
Volvo S80 2007 L6 3.2L V8 4.4L 6 Spd AWD AWTF80SC
Volvo S90 1997-98 L6 2.9L 4 Spd RWD A341E(30-40LE)
Volvo V40 2000 L4 1.9L 4 Spd FWD AW50-42LE
Volvo V40 2001-04 L4 1.9L 5 Spd FWD AW55-50SN
Volvo V50 2005-07 L5 2.4L 2.5L 5 Spd FWD AW55-50SN
Volvo V50 2005-07 L5 2.5L 5 Spd AWD AW55-50
Volvo V70 1998-00 L5 2.3L 2.4L 4L 4 Spd FWD DAW50-42LE
Volvo V70 1998-00 L5 2.3L 2.4L 2.5L 4 Spd AWD AW50-42LE
Volvo V70 2000-05 L5 2.3L 2.4L 2.5L 5 Spd AWD AW55-50
Volvo V70 2000-07 L5 2.3L 2.4L 2.5L 5 Spd FWD AW55-50SN
Volvo V70R 2006-07 L5 2.5L 6 Spd AWD TBD
Volvo V90 1997-98 L6 2.9L 4 Spd RWD A341E(30-40LE)
Volvo XC70 2003-07 L5 2.5L 5 Spd AWD AW55-50
Volvo XC90 2003-05 L6 2.9L 4 Spd AWD A341E(30-40LE)
Volvo XC90 2003-06 L5 2.5L 5 Spd AWD AW55-50
Volvo XC90 2003-06 L5 2.5L 5 Spd FWD AW55-50SN
Volvo XC90 2006-07 V8 4.3L 6 Spd AWD AWTF80SC
Volvo XC90 2007 L6 3.2L 6 Spd FWD/AWD AWTF80SC
Mijn 245, 1976, B21A had een BW55, nu een AW71.
Heeft de mannen in Woudenberg wel wat meer zweet gekost dan verwacht.
Past in principe wel, maar bedenk dat de 1976-ers nog geen gaten hebben om baksteun naar achter te zetten. Ook heb je wrs een mechanische tellerkabel, en de meeste nieuwere bakken een electronische. Zo is er meer dat niet zondermeer past of compatibel is.
Maar ik rij alweer een tijdje ermee rond, dus het is wel passend te maken! Al vergt het wel wat creativiteit en wat meer werk dus...
Het pas-maken van de AW70, 70L en AW71, 71L zijn mij bekend. Zie heel wat topics.
Mijn vraag betreft alles behalve deze...
??? Omdat.. Deze typen, zeker welke afkomstig van een 240, met een acceptabele km-stand en met toebehoren niet voor het oprapen liggen.
Maar, wie niet waagt wie niet wint, dus mogelijk heeft iemand al andere alternatieven geprobeerd ?
Beetje handig krijgt alles voor elkaar. Wat vindt je zelf haalbaar?
Binnen de grenzen van redelijk denk ik dat alles waar FWD of AWD achter staat niet lollig meer is. Blok ligt dwars bij deze auto's (en die van ons in de lengte)
Hoewel een 240 AWD wel weer een uitdaging is.....
`88 245, B230K, M47
Big Grin Ja,Ja... Allwheeldrive 245... Zie het helemaal voor mij.
Maar om bij de vraag te blijven;
Wie heeft ERVARING met een van de automaten en weet uit de PRAKTIJK de ins en outs ivm de (on)mogelijkheden van het bouwen aan een B21A :Smile
jero schreef:Het pas-maken van de AW70, 70L en AW71, 71L zijn mij bekend. Zie heel wat topics.
Sorry hoor, je verdere voorkennis bleek echter niet uit je vraagstelling. Dus neem me niet kwalijk dat ik je wilde attenderen op het feit dat vele van de topics wat optimistischer zijn dan dat voor mijn (en dus ook jouw) configuratie terecht bleek. Een 86er is wel voorbereid op de AW71 (of 03-71), een 1976 zeker niet. Ik noemde al baksteun gaten, maar ook kickdownkabel wordt te kort, en tellerkabel ook. ook is de tunnel te smal om de mechanische tellerkabel zonder rare hoeken naar voor te leiden. Details, maar wel erg frustrerend als je hier leest dat het zonder problemen allemaal past. Maar jou dus allemaal allang bekend. Dan kan ik je dus niet verder helpen....
Big Grin Dat de tunnel te smal is, is nieuw voor mij. Dit detail heb ik nog niet in andere topics gelezen. Is dit zó kritisch dat ik een modernere tunnel moet inlassen, of valt het binnen de categorie "erg lastig" ?
Meer van deze details of verwijzingen naar specifieke topics zijn van harte welkom. 8)
Andere tunnel hoeft niet, zo erg is het ook wee rniet. Maar de kabel maakt wel een scherpere bocht dan je zou willen. Maar het past wel, met een rare bocht, en wat milde pressie... Wink
Alternatief is uiteraard electronisch (ook makkelijk te vinden qua bak) en dan je teller ombouwen, er zijn ook units die een electronsch signaal weer in een mechanisch signaal converteren. Kun je traploos ijken, ben je ook van die circa 10% afwijking af..
Converter: kijk op http://www.hukebasart.nl/. zelf dus geen ervaring mee...
Volgens mij ben je met het passend maken van andere bakken dan een AW70, AW71, AW70L, AW71L (en die laatste twee tot een bepaald bouwjaar) zoveel geld kwijt aan aanpassingen, dat je beter wat meer kunt betalen voor een relatief makkelijk passende bak.
Een paar nuttige topics:
AW71(L) voor BW55
Mechanische km teller aandrijving op een AW71L bouwen?
Ombouw van 3- naar 4-traps automat, iemand ervaring mee?
245 GLE automaat naar AW .. (in ieder geval met lockout) ombouwen
AW70/71 L plug and play onder 244 modeljaar 1983?
ZF 4HP-22 op een 240?
En met de zoekfunctie is nog wel het nodige meer te vinden
Okay...
Leuk dat jullie allemaal gereageerd hebben.
Maar...
Mag ik concluderen dat er geen opties bekend zijn tussen de andere bakken in bovenstaande lijst, anders dan de bekende AW70,AW70L,AW71,AW71L?
  Welke motor voor AW 72 bak. Madman 7 3.758 19 January 2025, 21:07
  Welke olie in sperdifferentieel 940 i.c. bj. 96 JanO 2 2.215 4 December 2022, 22:32
  Welke automaat? Archermusic 10 10.171 13 August 2019, 15:29
Laatste bericht: aRjen.T
  past een M46 (Overdrive J-type) uit een 960 in een 740 Turbodiesel? nullifie 3 4.719 14 March 2019, 23:03
Laatste bericht: nullifie
  welke achteras volvo 240 voor een P1800es? gydomatra 12 18.519 28 September 2018, 15:28
  welke M47? jos245 1 3.427 24 January 2018, 17:00
Laatste bericht: asterix
  Welke automaat Amazon 221 6 7.674 3 January 2018, 10:01
  AW70 i.p.v. BW55. Past dat op een 6cil? petervanriemsdijk 11 15.317 2 October 2017, 10:45
  Welke jongere bak achter een B20 Jambon 3 5.801 30 June 2017, 23:55
Laatste bericht: Arn02
  welke olie AW 03-70L skidje 10 13.435 4 May 2015, 07:02
