Kleppen uitwisselen (cilinderkop)
BirnieF245 schreef:FF off topic
Sodium(Engels) is Natrium, Scheikundig naamgeving.Na.
natrium is een zeer onedel metaal wat in zuivere vorm bijzonder heftig(explosief) reageert met water.
Vandaar ook dat er in Bentley vermeldt staat dat Natriumgevulde kleppen niet zomaar weggegooid mogen worden.
Deze moet je eerst onschadelijk maken in water.
Klopt! Ik heb t even nagezocht en vond dit:
Citaat:Sodium (IPA: /ˈsəʊdiəm/) is a chemical element which has the symbol Na (Latin: natrium), atomic number 11, atomic mass 22.9898 g/mol, oxidation number +1. Sodium is a soft, silvery white, highly reactive element and is a member of the alkali metals within "group 1" (formerly known as ‘group IA’). It has only one stable isotope, 23Na. Sodium was first isolated by Sir Humphry Davy in 1807 by passing an electric current through molten sodium hydroxide. Sodium quickly oxidizes in air so it must be stored in an inert environment such as kerosene. Sodium is present in great quantities in the earth's oceans as sodium chloride. It is also a component of many minerals, and it is an essential element for animal life. As such, it is classified as a “dietary inorganic macro-mineral.”
Citaat:Applications
Sodium in its metallic form can be used to refine some reactive metals, such as zirconium and potassium, from their compounds. This alkali metal as the Na+ ion is vital to animal life. Other uses:
  • In certain alloys to improve their structure.
    In soap, in combination with fatty acids. Sodium soaps are harder (higher melting) soaps than potassium soaps.
    To descale metal (make its surface smooth).
    To purify molten metals.
    In sodium vapor lamps, an efficient means of producing light from electricity (see the picture), often used for street lighting in cities. Low-pressure sodium lamps give a distinctive yellow-orange light which consists primarily of the twin sodium D lines. High-pressure sodium lamps give a more natural peach-colored light, composed of wavelengths spread much more widely across the spectrum.
    As a heat transfer fluid in some types of nuclear reactors and inside the hollow valves of high-performance internal combustion engines.
    NaCl, a compound of sodium ions and chloride ions, is an important heat transfer material.
    In organic synthesis, sodium is used as a reducing agent, for example in the Birch reduction.
    In chemistry, sodium is often used either alone or with potassium in an alloy, NaK as a desiccant for drying solvents. Used with benzophenone, it forms an intense blue coloration when the solvent is dry and oxygen-free.
En daar is tie dan! Lijkt fonkelnieuw. Ik maak nog wel meer foto's als ie er op gaat. Hij ligt nu nog mooi in het cellofaan.
[Afbeelding: 06092007cs3.th.jpg]
[Afbeelding: 06092007003yt0.th.jpg]
[Afbeelding: 06092007001qm2.th.jpg]
grappig.
Ziet er goed uit AJ.
Lijkt er op dat er nu eindelijk iets goed gaat met je Turbo, mag ook onderhand wel met al die tegenslag.
Als nieuw, moet nu zeker gaan lukken met de opbouw.
Veel succ6
Mooi man!
Ziet er goed uit zo! Ik hoop dat het allemaal gladjes verloopt vanaf nu?
vergeet niet een nieuwe gaskabel te bestellen en iets voor je intercooler-inlaatspruitstuk aansluiting te regelen nu je een ander inlaatspruitstuk gaat monteren.
Jelmar schreef:grappig.
Wat ben jij nou weer droog, dr. Turbo! Wink Nee maar ff zonder gekheid. Ben echt blij ermee. Ziet er degelijk uit. Bedankt ook voor jullie medeleven en inderdaad nu hopen dat het allemaal wat minder gaat tegenzitten! 8)
fotootjes zijn niet heel geweldig met een mobiel maar toch, je ziet wel dat het er goed uit moet zien denk ik. 8) 8)
Morgen/zaterdag even proberen de downpipe los te krijgen. ÉÃn van de boutjes heeft een innige relatie met het moertje onder de wagen. Dus die moet ik nog lospeuteren. Ik heb geregeld dat ik het lasapparaat op mn werk mag (mis)bruiken!! Dus dat is handig als we straks de wideband gaan inbrengen! 8)
Ook mooi om te vermelden en het getuigt echt van service; Ik kreeg van de rivisieboer nogwel gewoon tapjes mee om de kopboutgaten na te lopen! Dus die moet ik er ff doorheenhalen dan kan ik ze weer teruggeven.
Dus Verkaik BV in Delft: BEDANKT!! Wink ;D Een aanrader voor iedereen hier in de regio!
Gaskabel heb ik nog niet. Weet jij welke ik nu moet hebben? Van een B230FK lijkt me of niet? Intercoolerpiping gaan we later doen als we eea al geplaatst hebben. Jelmar heeft mooie ideetjes daaromtrent. En misschien kan ik zelf nog wel wat rechte stukken alu buis regelen. Wicht reminds me: dat heeft Bosma ook al gedaan dus ik vraag hem wel ff welke diameter buizen en lengtes het zijn. Of als ie dit leest...kom maar op met die info! ;D
Zo, dat klinkt allemaal goed en ziet er zo mogelijk nog beter uit! ;D
Gr 8)
Thanks, we gaan gewoon DOOR! 8) ;D
Mag ik vragen wat je oor de koprevisie hebt betaald?
  Cilinderkop 1000160 vervangen door 1000530. Past dat? blauwe pijl 6 512 29 August 2026, 19:20
Laatste bericht: blauwe pijl
  Afdichtingsplug cilinderkop plaatsen heideltje 7 5.145 21 December 2020, 20:05
  Cilinderkop B230A nog te gebruiken of??? gillestuur 29 813 2 September 2019, 22:24
Laatste bericht: gillestuur
  B20 cilinderkop jacob.bijsterbosch 5 9.661 14 May 2018, 21:55
Laatste bericht: jacob.bijsterbosch
  Kleppen tikke 240 b230f laatste type KennOne 8 9.733 5 September 2016, 14:48
  Turbospruitstukken uitwisselen Dopski 17 17.933 6 March 2016, 21:16
  Controleren geharde klepzetels cilinderkop ZOAB 2 4.666 15 March 2015, 23:34
Laatste bericht: A_A
  Past een b21ET cilinderkop op een b230 FT onderblok? edwin 8 9.105 19 October 2013, 21:01
  "Houdbaarheid" gereviseerde cilinderkop 345GLS 6 7.223 20 April 2013, 20:06
Laatste bericht: 345GLS
  Gezonde kleppen + zittingen herkennen keter 11 12.495 6 November 2012, 21:35
Laatste bericht: oudevolvo
