Eindelijk.... kunnen onze Volvo's een stuk goedkoper rijden
Ik kwam dit tegen op de Zweedse Volvo site.
http://www.lindbergers.com/ws/3629-neo-s...10-30.html
Als je dit koopt wil je belazerd worden. Of.... is het toch waar? :Smile
"This simple electronic invention has managed to solve everyone's concerns about saving money on gas and reducing our car's impact on the environment."
Denna produkt arbetar med att få bilens elektronik att arbeta så balanserat och effektivt som det bara är möjligt. Med detta blir resultatet bättre tändsystem, lägre bensinförbrukning och i de flesta fall en märkbar ökning i effekt (hk).
Innan vi själva hunnit översätta några artiklar, rewievs, och manualer så hänvisar vi till den information som kommer från leverantören och som finns på engelska.
Säljs även på Amazon.com för $99
* The fuel economizer is a break-through, patent-pending invention in fuel conservation. The fuel economizer will let you save on petrol just by plugging it into your cigarette lighter socket. Your petrol consumption will decrease by 10% to 30%.
* The fuel economizer is fitted with an electrolytic capacitor that connects to the cars main electrical system electronically.
* It acts like a small battery that helps your car''s electrical system perform better. The capacitor then charges and discharges voltage when there is heavy demand from the alternator. Instead of the battery working overtime, the fuel economizer compensates the required voltage for devices such as lights, windscreen wipers, stereo, air conditioning and sat nav. Instead of the alternator and battery having to work overtime, the device supplements the required voltage to reduce the load on the electrical system from any accessory that is being used.
* The reduced electrical demand frees up energy that can be better used to deliver a more constant and steady supply of electricity to the spark plugs and ignition system. The result is a more efficient and complete combustion of petrol which will improve you gas mileage and produce cleaner emissions.
* This in turn WILL save you money. The blue LED will light up once the connection is made. This tells you that the fuel economizer is silently working.
* Features:
1) Increased Gas Mileage
2) Hi-Grade (Blue)
3) Save on gas by 10% to 30%
4) Cleaner emission
5) More horse power
6) Longer battery life
7) Too easy to use and start working instantly
8) As seen on TV
Dus een simpel electronisch ding kan via de sigarettenaansluiting ff mijn brandstof verbruik met 10-30% verminderen...
Iemand die dit serieus neemt moet zich dan maar laten belazeren (of nie...) en dan hier vertellen hoe blij hij ermee was/is.. ;D
Ok. Ik zal er maar mee voor de draad komen: Ik heb er drie via een verdelerblok op mijn sigaretten aansteker aangesloten.
Ik hoef nu maar eens per maand te tanken i.p.v. elke week. Big Grin
Geniaal! Af en toe zou ik willen dat ik het had verzonnen.
Even vrij vertaald: Je prikt een dingetje in je sigarettenaansteker met daarin een condensator. Die condensator werkt als een soort batterij en kan zich op- en ontladen (Daar is geen woord van gelogen). Hiermee neemt hij het zware werk van de accu over op het moment dat deze teveel voor z'n kiezen krijgt.
Gezien het formaat is het een relatief kleine condensator. Eenmaal opgeladen kun je een LED wel tot een paar minuten (optimistisch) van stroom voorzien maar moet dit je elektrisch systeem overeind houden? Stierep**p. Als dat met zo'n klein dingetje kan, dan moeten al die petjes met megawatts geluid (welke ook worden gebufferd door flinke condensatoren) bijna gratis rijden als ze het geluid niet aan hebben.... ;D
`88 245, B230K, M47
precies, ik heb ook altijd 1F condensator achterin gehad, 1 op 6 in de stad was prima haalbaar...
En nu?
`88 245, B230K, M47
1 op 10 dankzij de minder zware voet, 1 Stromberg ipv Webert, M46 ipv M40, Ãn de sub plus toebehoren niet achterin, dat scheelt kilo's... Wink
Citaat:1 op 10 dankzij de minder zware voet
ben je zoveel afgevallen dan Wink
[Afbeelding: blackmoose.png]
VW T3 camper TD
beetje..
Vind je het gek met 2 van die slurpperts aan boord en nu maar 1 mono je hebt ook maar 1 Tank moet je maar denken. 8)
  Vloeken in de kerk, post je auto die GEEN Volvo is. SanderGLT 96 112.162 3 August 2020, 20:59
Laatste bericht: Arjan.
  mini volvo's Laurens Zondag 7 10.670 23 February 2016, 21:16
  Zakelijk rijden binnenshuis Potvisboer 2 5.827 21 June 2015, 10:04
  PlayStation en Volvo :) A_A 3 7.196 28 February 2015, 01:19
Laatste bericht: A_A
  Je volvo wishlist - top 5 - Dopski 14 32.912 8 February 2015, 23:35
Laatste bericht: Arn02
  eindelijk een passend liedje voor in de 244 van een geweldige band... Jaap SHREK 5 7.958 23 November 2014, 12:35
Laatste bericht: Jaap SHREK
  Volvo 240 Wagon vs The New York International Auto Show Rob 1 7.950 17 May 2014, 11:21
Laatste bericht: Tube-Less
  volvo rap A_A 9 11.785 27 April 2014, 01:36
Laatste bericht: RayFrancis
  Wat voor volvo spul ben jij weleens kwijtgeraakt? Dopski 18 23.097 1 April 2014, 19:06
  Gezocht: contactpersoon volvo-forum.nl martin_b 5 7.271 20 January 2014, 22:20
