Motorcode waar te vinden?
In de 264 die ik heb zit een 4 cilinder, ik wil graag weten welke motor.
Links op het motorblok (voor de auto staan) staat 1000 398.
Is hier iets uit te herleiden??
Al vast bedankt!
Dat nummer slaat/staat op de kop
Citaat:1000398: Very similar to 1000160. Usually with big coolant passages, some have been made with small coolant passages. Also so called "little" head. Used with b19, b21 and b23 engines. The older type of cam cover fits to this, the newer does not.
Citaat:(door Jambon)Doe mij een lol en kijk eens rechts op het motorblok, tussen oliefilter en motorsteun, daar staat B230 of B200.
Of achter de stroomverdeler, daar staat de complete motorcode in een vlak stukje motorblok geponst.
[Afbeelding: blackmoose.png]
VW T3 camper TD
heuh..?
de verschillende koppen:
Citaat
Citaat
Ok, there are 5 (well, 6 if you count the 1000631) different 8 valve heads for the volvo redblock engine. They are as follows:
1000160: the oldest head. Usually with big coolant passages, some have been made with small coolant passages. So called "little" head. Used with early b21 engines. The older type of cam cover fits to this, the newer does not.
1000530: Very similar exhaust and intake passages as on the -160 and -398 heads. Always with small coolant passages. This too is a so called "little" head. The newer type of cam cover fits to this, the older does not. The head mounted spark distributor can be used with this head. Used on b200 and b230 engines.
1000405: This is a so called "big" head. Has usually big coolant passages, but some are made with small coolant passages. Usually comes with k-jet injector holes, but some are without. The older type of cam cover fits to this, the newer does not. Used with some b23 engines. In euro version the H cam was used with this head on the volvo 242 GT with the b23e engine.
1000531: This too is a so called "big" head. Always with small coolant passages. The newer type of cam cover fits to this, the older does not. The head mounted spark distributor can be used with this head. Used on some b230 engines. This is considered to be the best std. 8v head. This head never has the k-jet holes as standard. They can be made to this head though.
The 405 and 531 flow pretty much the same. Both flow more than the 160, 398 or the 530. Small coolant passages are desirable, because with them the chance of blowing your head gasket is reduced signifanctly. Also the heads with small coolant passages are less prone to cracking.
The 160, 398 and 530 flow pretty much the same. They all can come with or without k-jet injector holes.
All heads, 1000160, 1000398, 1000530, 1000405 and 1000531, come with 44mm intake valve and a 35mm exhaust valve.
Then there is the heron head head, which i believe is 1000631. It is completeally different from any of the above. It has no combustion chamber.
Jambon schreef:heuh..?
Wat? Dubbel posten makkelijker ???
VW T3 camper TD
sorry, dacht dat ie aanvankelijk hier thuis hoorde.. Wink
Ik gaf het lijstje aan als voorbeeld in het andere topic, dit topic is weer een voorbeeld van antwoorden die allang eens gegeven zijn in andere topics, maar 'moeilijk' te vinden zijn. ;D
VW T3 camper TD
komt goed..
okà bedankt het is al iets duidelijker, Ik moet voor de code dus rechts kijken.
Ik had bij zoeken wel motorcode getikt maar toevallig niks gevonden :-[ of wat bedoel je met het andere topic??
okkehel schreef::-[ of wat bedoel je met het andere topic??
laat maar, heeft r niks mee te maken.. Wink
  Motorsteun rechts origineel Volvo, waar te krijgen? TeunTimmermans 1 2.675 7 August 2021, 17:57
  Olielekkage, maar waar? Grey240Polar 22 17.748 18 May 2019, 09:33
  Motorcode Volvo Penta B18 MacVolvo 1 3.310 10 August 2017, 23:45
  Olielekkage Volvo 240, maar waar? Erikvolvolvo 1 3.869 28 May 2016, 16:55
  HELP, vacuumslang uit inlaatspruitstuk. waar moet deze? Eggie 9 9.189 21 July 2013, 14:39
Laatste bericht: Eggie
  Waar is dit ding voor? Volvo dude 4 3.808 23 October 2012, 21:15
Laatste bericht: Volvo dude
  Waar zit de koelvloeistof temperatuur sensor? B19et Basta 9 7.594 16 October 2012, 19:24
Laatste bericht: Basta
  Waar zit de resistor pack voor injectoren? GOLDEN TURBO 0 1.963 16 September 2012, 22:51
Laatste bericht: GOLDEN TURBO
  Waar staat het motortype? Drk 5 5.292 23 April 2012, 16:05
  Dieselblok kopen - waar op te letten? Patrick245 1 2.304 2 April 2011, 09:17
