Order bij FCP Groton, hoeveel tax?
Ik heb een order opgesteld voor FCP Groton en sta nu op het punt om de order te plaatsen. De vraag is echter: "hoeveel belasting moet ik gaan betalen aan de Nederlandse schatkist?"
Heeft iemand hier ervaring mee?
Hieronder staat de order:
Product Name Part # Price Qty. Total Price
1976-1982 Volvo 240 Bosch Ignition Wire Set
09232 $34.00
1 $34.00
1981-1982 Volvo 240 Distributor Rotor
04033 $4.75
1 $4.75
1981-1982 Volvo 240 Distributor Cap
03010 $5.00
1 $5.00
1976-1982 Volvo 240 Bosch Platinum Spark Plug
4216 $2.25
4 $9.00
1978-1981 Volvo 240 Fuel Pump Relay
3523639 $24.50
1 $24.50
1976-1982 Volvo 240 Sway Bar Link Kit
1206667 $12.00
2 $24.00
1976-1981 Volvo 240 Ball Joint
274117 $20.00
2 $40.00
1976-1982 Volvo 240 Oil Drain Plug
948187 $2.00
1 $2.00
1976-1982 Volvo 240 New OEM Oil Filter
W917 $3.95
2 $7.90
1976-1982 Volvo 240 Oil Filler Cap Gasket
940096 $0.65
1 $0.65
1981-1982 Volvo 240 Fuel Filter
71039 $11.00
1 $11.00
1976-1992 Volvo 240 Timing Belt Kit
240TBKIT $15.00
1 $15.00
1976-1982 Volvo 240 Timing Belt Tensioner
463633 $22.00
1 $22.00
1976-1982 Volvo 240 Alternator Belt Set
10X925S $10.00
1 $10.00
1976-1982 Volvo 240 Throttle Body Gasket
1271488 $0.75
1 $0.75
1985-1992 Volvo 740 Turbo Throttle Body Gasket
1271488 $0.75
1 $0.75
1985-1992 Volvo 740 Turbo Fuel Filter
71039 $11.00
1 $11.00
1985-1992 Volvo 740 Turbo Oil Drain Plug
948187 $2.00
1 $2.00
1985-1992 Volvo 740 Turbo Oil Filler Cap Gasket
940096 $0.65
1 $0.65
1985-1992 Volvo 740 Turbo Ball Joint
270477 $13.50
2 $27.00
1985-1992 Volvo 740 Turbo Front Control Arm Bushing-Aftermarket
6819057 $5.00
2 $10.00
1985-1987 Volvo 740 Turbo Spark Plug Wire Set-Bosch
09235 $43.00
1 $43.00
1985-1992 Volvo 740 Turbo Distributor Rotor
04169 $7.50
1 $7.50
1985-1992 Volvo 740 Turbo Distributor Housing Seal Kit
969330K $3.00
1 $3.00
1985-1992 Volvo 740 Turbo Bosch Platinum Spark Plug
4216 $2.25
4 $9.00
1985-1992 Volvo 740 Turbo K&N Air Filter
33-2043 $57.50
1 $57.50
1985-1992 Volvo 740 Turbo Brake Pedal Pad-Models With Automatic Transmission
1272066 $2.50
1 $2.50
1976-1982 Volvo 240 Thermostat-87 Degrees
273459 $9.00
1 $9.00
1976-1982 Volvo 240 Expansion Tank-Aftermarket
9142000A $20.00
1 $20.00
1976-1982 Volvo 240 Upper Radiator Hose
270615 $7.00
1 $7.00
1976-1982 Volvo 240 Lower Radiator Hose
270616 $7.00
1 $7.00
1976-1982 Volvo 240 Expansion Tank Hose
9141262 $7.00
1 $7.00
1985-1992 Volvo 740 Turbo Thermostat-87 Degrees
273459 $9.00
1 $9.00
1985-1992 Volvo 740 Turbo Water Pump-Bugatti
271975A $36.00
1 $36.00
Grand Totals:
Shopping Cart sub-total: $479.45
Shipping: $115.20
Sales Tax: $0.00
Grand Total: $594.65
Volvo 740 tic '84.
Voorzover ik het via googlen te weten kan komen:
14% import toeslag USA->Europe (verschilt per soort goederen)
daarover 4% Invoerbelasting
en tot slot daarover 19% BTW.
Maar ik laat jaarlijks voor ongeveer € 1000 uit het buitenland naar me toesturen en heb nog nooit een Eurie aan belasting er bovenop gehad. ;D ;D
even laten aangeven door fcp dat het om 2e hands artikelen gaat ;D
Volgens de wet zijn bedrijven in de US verplicht de juiste waarde van de goederen op te geven. :-[
Dus je kan vragen wat je wil, de meeste bedrijven hebben liever ruzie met jou als met de wet. :Smile
De bestelling is onderweg. Ik ben benieuwd hoeveel invoerrechten en BTW ik moet betalen. De totale order inclusief verzendkosten = $913,00.
Volvo 740 tic '84.
Citaat:Volgens de wet zijn bedrijven in de US verplicht de juiste waarde van de goederen op te geven.
Vele malen bij FCP besteld en altijd zonder problemen zetten ze een lagere waarde op de doos.
(1 van de laatse keren stond er $25 op ipv $470 Big Grin )
Hmmm,
Weer een FCP-order geplaatst (7 dagen later in huis, dus dat valt wel weer mee; iig sneller dan EstateServices)
Parts: $86,50
Shipp: $58,75
TOT: $145,25
Douanewaarde: €55
BTW bij invoer: €15,39 (28%)
Inklaringskosten: €16,75
TOT: €32,14
Dus in totaal kwijt: $145,25 + €32,14 = €116,55 (is exact 2 x de bestelde waarde :o )
Valt me deze keer een beetje tegen >Sad
- Oliescheider (breatherbox)
- O-ring
- Kleppendekselpakking
- Spruitstukpakking
- 2x Stabilisatorstang voor, incl. bussen
- 2x Antirollbar bussen PU (Superflex)
- 2x Dynamo-ophangbus PU (Superflex)
vragen of ze het met USPS sturen ipv UPS, die zijn veel coulanter( geen BTW over de vrachtkosten bijv) en ook vragen of de waarde van je bestelling onder de $50.- kan worden opgegeven Wink Wink
Land Rover 110. 200TDi ' 84
BMW E23 ' 83
V70 t-5 ' 99
Dit was met USPS, met UPS was het $105 duurder :o
(Btw is ook alleen berekend over de parts en niet over de shipping)
FCp is trouwens ook duurder geworden sinds ze een nieuwe site hebben ( sommige onderdelen 25% of meer).
Voorheen mailde ik mijn bestelling rechtstreeks aan een medewerker van FCP.
Die zette het dan voor mij om in een order en zo kon ik dan ook vragen om een lagere waarde.
Nu dus via de nieuwe site de order ingelegd, en gehoopt dat de douane niet zou ingrijpen.
Pech dus.
Anyway; you win some, you loose some en zoals ik gister ergens op het net las:
"If it has pistons or tits, its going to be expensive. " Big Grin Big Grin
Rob schreef:"If it has pistons or tits, its going to be expensive. " Big Grin Big Grin
tijd voor een auto met gasturbine!
  Hoeveel rijden er nog rond? jos245 11 19.391 11 October 2020, 12:31
  Hoeveel oude Volvo's zijn er nog? LoekS 11 14.510 22 June 2018, 22:29
  Hoeveel rijden er nog rond? 265gl 0 2.993 12 July 2014, 10:30
Laatste bericht: 265gl
  Korting bij FCP Groton Bazis 3 4.924 25 January 2012, 20:54
Laatste bericht: oudevolvo
  Gezamenlijk bestellen bij FCP Groton Erik265 41 31.651 30 December 2007, 03:31
  FCP Groton?? Frans245 6 5.921 19 September 2007, 22:29
  Hoeveel km 240estate 39 28.676 19 November 2006, 18:27
Laatste bericht: 240estate
