Voor de intercoolers onder ons
mooi setje. En deze kerel is zeer betrouwbaar (en niet duur). Ik heb van hem de hele intercoolerset compleet gekocht. En laatst nog een cruisecontrol kitje plus wat metertjes.
Volvo 240 Turbo Intercooler OE UPDATE Boost Kit fan etc
http://cgi.ebay.com/ebaymotors/ws/eBayIS...Track=true
Citaat:You are bidding on a complete genuine Volvo factory boost UPGRADE kit.Easily installed in ANY intercooled 240 Turbo,these parts were only found on very late production 240 Intercooled turbos,......and what a difference they make!
When Volvo began intercooling their 240 turbos they used an electronic boost control circuit that used one,(rather large) relay mounted on the right inner fender well,near the boost control solenoid and coolant resivoir bottle.It's sole purpose was to control a solenoid that controlled boost pressure determined by RPM.In other words once you hit a certain RPM the relay would activate the solenoid and allow more boost to occur.Late into the 1984 production year Volvo started installing an improved boost control electronics circuit.......Much improved!
The later electronics,(as offered here),use 3 seperate relays.One controls the solenoid that controls boost pressure.One is a relay that goes to a fitting that is installed with a sensor in the lower radiator hose,(included),and then goes to an auxilary fan,(also included),mounted in front of the AC condensor so that when temps rise the fan is kicked on providing more cooling meaning ultimately you can run higher boost pressures.The third relay is used to turn off the Air conditioning under boost.After cranking up the boost you'll find the combination of the three systems provides a difference you can truely feel! You'll be amazed.
Now to put to rest some of the myths and mystery surrounding 240 Turbo boost electronics.There is no such thing as "Turbo Plus" kit for 240 series cars.(this kit is the closest you'll come),ALL intercooled 240's had electronics to control a solenoid to achieve the results described above.I think the confusion arises because 740/760/940 cars DID have a "turbo plus" kit available as an accessory that added similar (looking) components.(A control box,solenoid,wiring and some hose).The systems operate very differently though.On the 240 Boost is supressed below a certain RPM where as the 700/900 "Plus kit" upped the boost in relation to the throttle position sensors readings,(at full throttle basically).If anything were to be considered a "plus kit" for the 240 it would be the three relay setup,(offered here),that was standard on the late 240 turbos as described above.And it was never offered as an "accessory".The larger earlier relay you see offered sometimes as a "plus kit" was standard on every 240 turbo that was intercooled through mid 84.
Included is EVERYTHING you need! Wiring harness,3 relays,relay mounting bracket,lower hose fitting and sensor and factory cooling fan and bracketry that went out in front of the AC condensor.(Your current boost solenoid is the same).That's everything you need to install this kit and reap the benefits.ALL parts are in nice condition as well! You can mess around with other aftermarket gadgets that control boost manually or "Frankenstein in" someone elses half witted idea but the bottom line is,this system was designed at the factory to attain maximum boost without harming your engine. I can include some installation tips as well as a factory wiring diagram.I recently discovered,on a lot of 85 240 turbos this wiring harness is incorporated into the main wiring harness making it a real pain to remove.Grab this stand alone harness while you have the chance."Buy it now" price is lower than what I sold the last one for a few weeks ago.
You pay actual shipping.
149 dollar (ex. alles) voor een fan, een temp.sensor en 3 relais' is wel heeeeeel erg duur IMHO :twisted:
Gr Confusedhock:
Citaat:149 dollar (ex. alles) voor een fan, een temp.sensor en 3 relais' is wel heeeeeel erg duur IMHO :twisted:
Ja, de 'buy now' optie is idd erg duur, maar als je gewoon een bod doet kom je echt wel flink lager uit hoor. Let maar op. (vaker meegemaakt nl.)
Maar alleen al uit de omschrijving kun je het zelf maken.... 3 relais' nieuw a 5 euro, temp.sensor en fan (sloop 20 euro?) en een uurtje prutsen met kabeltjes en stekkertjes et voila 8)
Gr :?:
voor de handige harries is dat inderdaad een optie ja :-) :lol: Doe er je voordeel mee Thuur! :-)
beetje vreemde verkoper, op turbobricks hebben er al mensen problemen mee gehad (wel opgelost, niet echt slecht dus), en erg duur.
klinkt niet echt indrukwekkend die optie, gewoon zelf even knutselen en je hebt iets dat niet 20 jaar oud is.... en waarschijnlijk beter ook.
TheSaint77 schreef:voor de handige harries is dat inderdaad een optie ja :-) :lol: Doe er je voordeel mee Thuur! :-)
Laat ik nou niet het meest cruciale onderdeel hebben van deze setup... De solenoid :oops:
Gr :lol:
Passen trouwens intercoolers van de 7 en 9 serie op een 240 turbo? Zijn er nog meer modellen welke ook nog op een 240 turbo passen? En met 'passen' bedoel ik dus niet 'een dag sleutelend passend maken' Big Grin
Citaat:beetje vreemde verkoper, op turbobricks hebben er al mensen problemen mee gehad (wel opgelost, niet echt slecht dus), en erg duur.
nogmaals, via de buy now optie is het duur. Maar als je gewoon biedt dan merk je dat je het object voor een fractie kan kopen soms. En problemen...kijk maar eens hoeveel transacties het betreft. Logisch dat het een enkel keertje niet soepel gaat met transport enz. Maar qua persoon is het een gewoon een betrouwbare verkoper.
o je bedoelt dit:
http://www.haringen.eu/Volvo740turbo+.htm
heb ik al
244 DL Sedan 1984
C70 2.0T Convertible 2004
  Modelauto veiling voor de snelle beslisser (sluit binnen vier uur) Volvo 142 B23 2 7.225 23 October 2014, 18:05
  101 functies voor een snijplankje van de action in je auto Laurens Zondag 2 5.213 23 May 2014, 13:29
  Volvo 1800ES nieuw voor 73000 dollar sludge 3 4.764 14 January 2014, 15:34
  Leuk voor in de tuin... Jambon 3 4.069 21 March 2011, 03:28
Laatste bericht: Black Moose
  leuk voor in de gang... Jambon 3 4.319 25 January 2011, 17:09
Laatste bericht: nullifie
  Voor de liefhebber bij vadertje staat te koop! De Kater 32 23.626 21 April 2010, 16:12
Laatste bericht: Zwarte Flirt
  Een Group A 240 voor iedereen? ZwerverRoodbaard 11 9.975 31 March 2010, 19:37
Laatste bericht: Boele
  Tijdgenoot voor achter een "jonge" 240 Gandalf 2 3.234 18 March 2010, 09:50
Laatste bericht: Gandalf
  2 achterruiten voor een 245--> GRATIS! PP! 0 2.486 3 December 2009, 14:42
Laatste bericht: PP!
  Voor Volvo begint 1978 NU ***t_blijft_behelpen*** 3 3.384 4 November 2009, 22:15
Laatste bericht: PB240
