inspuitdruk?
Gevonden lijkt mij echt
http://www.volvo200.org/modellen/asp_pv7557_80_2.gif
244 GL D5 Estate Volvo was build in 0. With S-5 SOHC / 10 valves total / 2 valves per cylinder engine type, sized at 1986 ccm it was able to deliver 70.0 bhp @4800 rpm and 118.0 Nm (87 lbft) @3200 rpm of torque.
It is a RWD driven car, with Front engine location, wighted at 1420 kg. The car comes with a 4 Speed Manual transmition. and fuel capacity of 60 litres. compression ratio 24.00:1 and it is a Normal D. fueld engine. and brakes (F/R) Di/Di-S.
Car size was L/W/H 4880 mm/1710 mm/1450 mm and it is raisen from the ground for 140 mm.
