26 August 2010, 11:36
Non, non, non. Maison d'excès.
post hier je grootste sleutelblunder.
30 August 2010, 20:00
Na Dop's lijstje moest ik meteen aan de ze denken:
Peter Egan [Road & Track] Tool Dictionary: AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off. AVIATION METAL SNIPS: See hacksaw. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Snap-On Tool Calender over the bench grinder. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack. ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. HYDRAULIC FLOOR JACK: Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trapping the jack handle firmly under the front air dam. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers. OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round-out Phillips screw heads. PHONE: Tool for calling your neighbor Chris to see if he has another hydraulic floor jack. PLIERS: Used to round off bolt heads. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot. TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys. TWEEZERS: A tool for removing wood splinters. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect. TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. WHITWORTH SOCKETS: Once used for working on older British cars an motorcycles, they are now used mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt." ZIPPO LIGHTER: See oxyacetelene torch. Maar het duurde even voor ik hem tegenkwam.
2 September 2010, 15:51
Ik: wegrijden terwijl de achteras nog op pootjes staat... >
![]() Neefje: bobine kabel eraf trekken op motor uit te zetten: ow dat is dus 40.000 volt ;D Ik: starten zonder bougies > ![]() Wij: ondsteking verkeerd om ![]() Ik: WielBOUTEN losdraaien terwijl de auto nog op de grond staat > (niet mijn auto : )Wie niet???: starten met een losse accu pool. Neefje: grote hamer... Must i say more... Ik: Waarom moet er olie op een olie filter??? En zo hebben we nog wel wat meer gepruts....
2 September 2010, 17:42
Soms worden er tips gegeven waar je wat mee kan, soms mindere...
volvo-forum schreef:De temperatuur meter hoort in het midden te staan, althans dat was bij mijn auto wel zo, je kan ook de temperatuur meten na een flinke rit middels het open draaien van de radiateurdop en er dan een thermometer in de radiateur te stoppen. Temperatuur hoort dan zo'n 75 tot 85 graden te zijn, dit is afhankelijk van je thermostaat.Au.
2 September 2010, 17:59
Je mag toch hopen dat men zo wijs is om dat niet te doen.
9 March 2011, 08:48
Wordt net "getriggerd " door de foto's van de Rally 240.
Op de foto's laat men een rolmaat zien waar ze de afstand meten tussen wiel en veerpoot. Doet me denken aan weer een sleutelblunder van mij. Ik zag altijd dat het haakje los zat aan het lint en vloekte dat de fabriek die nageltjes weer niet goed geklonken had. Dus ik weer naar de bankschroef om die nageltjes te pletten waardoor dat haakje geen speling meer had . Blijkt later dat die speling wel degelijk een functie had...
9 March 2011, 09:03
edwin schreef:Wordt net "getriggerd " door de foto's van de Rally 240. Laatst zat ik met rolmaat te spelen. Toen bedacht ik me ook: "goh... slim... Alhoewel...na hoeveel meetfouten zijn ze daar achter gekomen"
Volvo 142S - 1973
Felix |
| Vloeken in de kerk, post je auto die GEEN Volvo is. | SanderGLT | 96 | 112.267 |
3 August 2020, 20:59 Laatste bericht: Arjan. |
| Gaat iemand hier naar toe? | A_A | 1 | 4.262 |
24 June 2014, 08:55 Laatste bericht: A_A |
| Ik ben nieuw hier dus ik stel mezelf even voor | CaptainIglo | 2 | 4.267 |
19 July 2013, 10:08 Laatste bericht: frox |
| Uitstapje naar s'werelds grootste autoshow | jos245 | 2 | 3.673 |
18 September 2011, 11:00 Laatste bericht: Jambon |
| Iemand zocht hier toch een 240 Koets ? | pwassink | 1 | 2.845 |
30 November 2008, 17:01 Laatste bericht: Jelmar |
| Wegens groot succes ook hier het ONZIN topic | Postma 245 GL | 450 | 228.450 |
22 March 2008, 14:37 Laatste bericht: Postma 245 GL |
| Wat klopt hier niet? | LJ | 21 | 15.985 |
29 October 2006, 10:00 Laatste bericht: MP |
| wat ben ik hier nou weer aan het doen | a.huis | 60 | 47.777 |
29 August 2006, 21:22 Laatste bericht: Peter Timmer |
